Viscous model choice
Old   March 15, 2008, 04:17
Default Viscous model choice
Luis Díaz
Hi!
I'm studying the aerodynamics of an airship. I'm simulating a 2D envelope shape (a streamline body) and I don't get correct results. I'm using a K-epsilon viscous model (standard model) but I've saw that in many tutorials the spallart-almaras model is chosen to simulate the aerodynamics of an airfoil.
Which model fits better my simulation, K-epsilon or spallart? Which are the main differences between them?
Thanks!
Luis
Old   March 15, 2008, 07:27
Default Re: Viscous model choice
Scott
Hi there,
You would be best to read section 12 of the User Guide. This will tell you the differences between the models, and give you an outline of what cases they will work best for.
It is my understanding that the Spalart-Almaras model is the best for airfoils at low angles of attack and I would reccommend that you use this for your problem. Read the manual so that you know why though. Also the manual will give you a better idea about what type of mesh you need at the wall, and the y+ values you should be using.
Regards,
Scott
Old   March 17, 2008, 05:30
Luis Díaz
Thank you Scott!
I think that I will use the Spallart model.
Luis
questions about V2F viscous model miguel FLUENT 9 July 11, 2016 17:31
Model choice for free air convection heat transfer Chris Bailey FLUENT 1 February 27, 2006 11:14
Which viscous model? Ali FLUENT 3 November 24, 2005 03:55
Turbulence model choice Peter Main CFD Forum 11 August 2, 2001 20:32
choice of turbulence model Sanjeeb Pal Main CFD Forum 1 February 11, 1999 11:22
