March 14, 2008, 17:58 |
FloWizard & Fluent
Is it possible import case and data files of fluent 6.3.26 on flowizard? Thanks in advance
Valerio |
March 14, 2008, 18:08 |
Re: FloWizard & Fluent
i cannot to import in release 2.0.4...is it a my problem or is it possibile with fw 2.1.8 or is not possible???
Thanks |
March 16, 2008, 18:23 |
Yes it is possible to read in Fluent cas/dat files. The current release of FW is v3.0.4 which uses Fluent v6.3.26 in the background. You cannot read case files from release Fluent into old FW versions as the Fluent solver in the older FW wont understand the newer files. So use v3.0.4 of FW and then you can read in the Fluent v6.3.26 and earlier files. Fluent case file settings at import are also limited to FW capabilities however so dont go reading in cases with multiphase settings , for example .., as FW cant read them !
March 16, 2008, 21:12 |
thanks red lemon!
