Drag UDF
Old   March 9, 2008, 08:26
Default Drag UDF
JK
hi as an exercize, i tried to specify the drag closure (Morsi-Alexander) explicitly through a udf, for a gas-liquid two phase flow. I am using euler-euler model and k-epsilon for turbulence.
The problem is that the simulation runs for some time and then says Invalid No: Floating Point error after say 500 time steps
I am confused as to what could be the problem. this is the code.. someone please help me out #include "udf.h"
#define diam 0.001
DEFINE_EXCHANGE_PROPERTY(custom_drag,cell,mix_thre ad,s_col,f_col) {
Thread *thread_g, *thread_l
real x_vel_g, x_vel_l, y_vel_g, y_vel_l, abs_v, slip_x, slip_y,
rho_g, rho_l, mu_l, reyp, tau, void_g, void_l, a1, a2, a3,
cd, f_drag, k_drag;
thread_g = THREAD_SUB_THREAD(mix_thread, f_col);/*gas*/
thread_l = THREAD_SUB_THREAD(mix_thread, s_col);/*liq*/
/*geting the velocities and properties*/
x_vel_g = C_U(cell, thread_g);
y_vel_g = C_V(cell, thread_g);
x_vel_l = C_U(cell, thread_l);
y_Vel_l = C_V(Cell, thread_l);
slip_x = x_vel_g - x_vel_l;
slip_y = y_vel_g - y_vel_l;
rho_g = C_R(cell, thread_g);
rho_l = C_R(cell, thread_l);
mu_l = C_MU_L(cell, thread_l);
/*slip velocity*/
abs_v = sqrt(slip_x*slip_x + slip_y*slip_y);
/*Relative Reynolds No:*/
reyp = rho_l*abs_v*diam/mu_l;
/*relaxation time*/
tau = rho_g*diam*diam/18/mu_l;
void_g = C_VOF(cell, thread_g); /*gas vol frac*/
void_l = 1.0 - void_g; /*liq vol frac*/
if(reyp < 0.1)
a1 = 0.0;
a2 = 24;
a3 = 0.0;
else if(reyp < 1.0)
a1 = 3.69;
a2 = 22.73;
a3 = 0.0903;
else if(reyp < 10.0)
a1 = 1.222;
a2 = 29.1667;
a3 = -3.8889;
else if(reyp < 100.0)
a1 = 0.6167;
a2 = 46.5;
a3 = -116.67;
else if(reyp < 1000.0)
a1 = 0.3644;
a2 = 98.33;
a3 = -2778.0;
else if(reyp < 5000.0)
a1 = 0.357;
a2 = 148.62;
a3 = -47500.0;
else if(reyp < 10000.0)
a1 = 0.46;
a2 = -490.546;
a3 = 578700.0;
else
a1 = 0.5191;
a2 = -1662.5;
a3 = 5416700.0;
/* now calculating cd*/
cd = a1 + a2/reyp + a3/reyp/reyp;
/* now calculating f*/
f_drag = cd*reyp/24.0;
/*now calculate k*/
k_drag = void_l*void_g*rho_l*f_drag/tau;
return k_drag; /*return drag coeff*/ }
thanx in advance
Old   March 10, 2008, 09:33
Default Re: Drag UDF
lurk
hi it may be that you using a integer one place and float all the other places. it's here: if(reyp < 0.1)
a1 = 0.0;
a2 = 24;
a3 = 0.0; try using a2 = 24.; i had the same problem myself -lurk
Pressure drag, friction drag and total drag? Cheng CFX 9 January 26, 2024 14:46
drag for AUV saran Main CFD Forum 1 October 6, 2016 07:59
DRAG Diego Flores FLUENT 4 April 17, 2011 08:48
Ram Drag Socrate FLUENT 0 May 23, 2007 04:14
UDF for Drag Srivatsan FLUENT 1 January 2, 2007 08:13
