May 6, 2020, 17:30 |
Are you sure the 4-6 layers is enough,but I think it is so few that cannot capture t
#21 |
Rep Power: 9 |
Are you sure the 4-6 layers is enough,but I think it is so few that cannot capture the flow boundary layer for the film,which has quite a strong velocity gradient.
May 7, 2020, 07:11 |
Laminar Flow
#22 |
You mentioned that the flow is laminar. Then the gradient cannot be high. High gradient implies turbulent flow. So, if the flow is really laminar and single-phase, you do not require any inflation layers at all, not even 4-6.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 7, 2020, 17:18 |
Do you have the theory which can verify your opinion?
#23 |
Rep Power: 9 |
May 8, 2020, 06:15 |
Theory
#24 |
Just pick up any fluid dynamics book that explains boundary layer and you will understand. For a laminar flow through a duct, the thickness of boundary layer is equal to radius while the thickness of boundary layer for a turbulent flow through the same duct is much smaller. Gradient increases as thickness reduces. For a laminar flow, velocity varies from 0 to maximum over r while for turbulent flow same variation occurs over a fraction of r. Which one in your opinion requires finer mesh? For the same reason, is not even available as a field variable in laminar flows, since it is not important.
May 8, 2020, 17:21 |
The thickness of boundary layer is equal to radius ? What is the radius? I have found
#25 |
Rep Power: 9 |
May 9, 2020, 17:10 |
Boundary Layer Thickness
#26 |
Radius implies radius of the duct through which fluid is flowing. The concept of boundary layer does not exist in undergrad texts. Analytical solution is usually based on similarity analysis and you can find it many books, such as, Boundary Layer Theory by Schlichting or in Convection Heat Transfer by Adrian Bejan. It is also called Blasius solution. You can find such work online as well. And it is not very time-taking and can even be derived within a post here. If you are mathematically oriented, then you can go through An Introduction to Fluid Dynamics by G.K.Batchelor, but only if you comfortable with mathematical analysis.
May 11, 2020, 13:49 |
Thank you for your answer. I have another question:I have set the use of manufactura
#27 | |
Rep Power: 9 |
May 11, 2020, 14:21 |
Doe
#28 |
I am afraid I do not have any idea about WB or DoEs.
May 12, 2020, 17:28 |
It does not matter. I have another problem, how should we set the residuals in the f
#29 |
Rep Power: 9 |
It does not matter. I have another problem, how should we set the residuals in the fluent if we have a transient flow? Is 1e-3 enough ? Or should we change it it under 1e-6 or more? Or we only observe the monitor variables?
Gambit and Tgrid | Vidya | FLUENT | 0 | August 9, 2006 23:22 |
[Commercial meshers] From GAMBIT to TGRID | kapel | OpenFOAM Meshing & Mesh Conversion | 0 | March 14, 2006 17:01 |
which Preprossecor Gambit Tgrid ....? | nasser | FLUENT | 2 | December 13, 2005 02:16 |
can tgrid be used like gambit? | frank | FLUENT | 1 | January 7, 2005 13:54 |
TGrid & Gambit!!! | Ahmed | FLUENT | 2 | June 29, 2003 20:22 |
