K-Epsilon Realizable
Old   March 7, 2008, 10:38
Default K-Epsilon Realizable
cristiano
The k-Epsilon standard is not good for the anisotropic turbulence cases. The Realizzable version? Is it good? And why?
thanks
Old   March 11, 2008, 07:27
Default Re: K-Epsilon Realizable
selvag
std k-e model is non-realizable model that means the eigen values of the reynolds stress tensor is negative. This is not true in actual flow. To overcome this limitation, realizable model is proposed. so it should give good results.
Realizable k-epsilon model Rana FLUENT 0 February 5, 2007 05:05
Realizable k-epsilon eqns for multiphase flow Rana FLUENT 0 December 8, 2006 14:46
Realizable K-epsilon settings Stephen Mar FLUENT 3 March 10, 2003 08:37
realizable k-epsilon turbulence model. J Keays. Main CFD Forum 17 December 6, 2000 04:47
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
