Gambit Import Error
Old   March 6, 2008, 15:01
Default Gambit Import Error
Shun Jie
Hi
I am having errors when importing mesh and cad files. Whenever i try to import a mesh file, i get the following error
" Process completed with exit code 1 Process completed with exit code -1 "
Also when i try to import step files, i get the following "ERROR: Unable to start InterOp translator. Translator is not installed or corrupt."
What do these errors mean?
Thanks.
Old   March 7, 2008, 02:42
Default Re: Gambit Import Error
Vinod Dhiman
Were you able to do it earlier? If not, then check your license. The lines required for import may be missing.
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
