udf wall distance segmentation violation
Old   March 6, 2008, 14:24
Default udf wall distance segmentation violation
gento
Dear all,
I would like to get the function C_WALL_DISTANCE(c,t) to work for an UDF that I use. If the flag "enhanced wall treatment" is selected everything works fine, otherwise a segmentation violation error occurs.
Does anybody know a way to go around this problem?
Best regards, Gento
Old   April 15, 2016, 16:59
Pratik Dhoot
pratikddhoot is on a distinguished road
I have the same problem. If you have found a way out yet, you can let me know.
Thanks.
pratikddhoot is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 08:29
UDF segmentation violation error be89 Fluent UDF and Scheme Programming 1 December 21, 2012 04:07
udf segmentation violation when hooked jjchristophe Fluent UDF and Scheme Programming 9 June 25, 2012 06:46
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
