Shadow Wall
Old   March 5, 2008, 16:39
Default Shadow Wall
Soheyl
What is the story behind this shadow wall thing? (when you have solid / fluid interface) What does it do?
Old   March 12, 2008, 14:45
Default Re: Shadow Wall
R.
a 2d surface that is defined as a wall with the domain on both sides will be split into 2 walls, one for each side, so that you can define a different bc for each.
If its not supposed to be a wall, then pick one of them and redefine it as an interior.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
wall shadow amar FLUENT 1 February 5, 2010 07:07
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
