Grid check fails after sliding mesh calculation
Old   March 3, 2008, 15:28
Default Grid check fails after sliding mesh calculation
Tito
I'm setting a case with sliding meshes. After defining the mesh motion, other boundaries, grid interfaces and so on I'm saving a case file which is ready for iteration after initialization. Rechecking the grid after writing this case file passes OK but when I run it and then save it(along with the data file) again every consequent attempt of checking the grid fails because of one left handed face found.
Note that this doesn't affect the convergence (I managed to converge 2 time steps with this 'bug') but it still bothers me. The Gambit exported .msh file is read with no left handed faces, same goes for the .cas file after setting the case before iteration. Calculation though always brings that in further grid checks.
I'm using coupled explicit solver (over 530000 nodes) with 4 level multigrid FAS scheme and I can't complain about convergence assuming the computing power I have at home.
Do I have to pay attention on that assuming that convergence is achieved? If yes, any idea what might cause it?
Thank you.
Sliding mesh and Momentum Theory Lam FLUENT 2 February 21, 2013 17:08
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
[Other] How to mesh the 1st grid point lakeat OpenFOAM Meshing & Mesh Conversion 1 October 8, 2007 08:13
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
