Difference in lift, inviscid comp. to viscid
Old   March 3, 2008, 14:40
Default Difference in lift, inviscid comp. to viscid
Stephan
Dear all,
I am simulating 2D-airfoils in a subsonic flow. Relevant for me is the total lift (force in y-direction). The strongly differing results from inviscid calculations compared to k-epsilon calculations (10 to 20% depending on the airfoil and angle of incidence) surprised me. I would expect some increase in pressure due to drag but not this much.
Do any of you have experienced the same and maybe know a percentage figure of the difference that is to be expected? Are there more reasons for this difference?
Thank you in advance for your help
Greetings Stephan
Old   March 3, 2008, 15:57
Default Re: Difference in lift, inviscid comp. to viscid
opaque
Dear Stephan,
Are you comparing two different turbulence models?
Opaque
Old   March 4, 2008, 15:28
Stephan
Dear Opaque,
thanks for answering. The purpose of my simulations is to find out whether I can use the inviscid (Euler-) solver to get the lift distribution without a major error or how big this error would be. The only turbulence model I used so far to compare the inviscid results to was the k-epsilon (realizable) model.
Greetings Stephan
Difference between Volume Fraction and Mass Fraction in CEL foo7 CFX 0 September 21, 2011 09:45
Saffman Lift Force: confused CFD_MAN FLUENT 5 September 9, 2010 05:51
Thin foil analsis (sail) - Lift Coeff Problem Kelvin CFX 3 December 22, 2008 17:22
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
How is lift generated at airfoils ? Victor Serov Main CFD Forum 19 August 16, 1999 00:45
