March 3, 2008, 12:57 |
phase change
Hello, I would like to simulate a flow, which has phase change, from water to vapor. I use the mixture/cavitation model. I calculate the vaporization pressure with a polynom. I use pressure inlet boundary condition for inflow, and pressure outlet for outflow. The outflow pressure lower, like the vaporization pressure. My problem: The fluent limit the pressure to the vaporization pressure and I don't know, why? If somebody know, please tell it to me
Thanks |
March 5, 2008, 03:42 |
Re: phase change
Please help me, it is very important for me. Thanks
March 5, 2008, 11:02 |
Re: phase change
Thanks Robert. It was pretty much what I was doing. I was concerned about the difference I was seeing over flow time. But the error was less than 1.5% That still should not exist but I guess it could be numerical error or something. I guess I won't worry about it.
March 5, 2008, 11:03 |
Re: phase change
sorry responded in the wrong section!
March 7, 2008, 02:03 |
Re: phase change
23.6.2 Wet Steam Flow Equations
The wet steam is a mixture of two-phases. The primary phase is the gaseous-phase consisting of water-vapor (denoted by the subscript v) while the secondary phase is the liquid-phase consisting of condensed-water droplets (denoted by the subscript l). ( and my dear u want to model inverse, i mean here fluent assume that the primary phase is steam, but in your case it is water and i can guess that u have given the boundary condition for water ( inlet condition), so i think we should use inlet boundary condiition for outlet and vice versa plz share your view |
March 7, 2008, 07:09 |
Re: phase change
for using wet vapors fluent have limitation of 273k to 647k, might be your temperature exceed this limits, that why it limits ur pressure
May 2, 2009, 07:17 |
helpppp
tuce
would somebody help me pleasee?I try to simulate two phase flow (water
boiling )by cfd .but I could not manage it.I really need its tutorials.my mail address is tuceyilmaz1984@hotmail.com ıf somebody helps I will be very glad.tnanks by now. |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 07:37 |
About phase change heat and mass transfer | Michael | FLUENT | 2 | February 13, 2011 02:49 |
Phase change | phdsantos | FLUENT | 0 | March 20, 2009 11:19 |
Two phase flow with phase change | Ahmad Al-Zoubi | CFX | 1 | November 26, 2008 04:59 |
How to model the solid-fluid phase change in CFX | ohrmond | CFX | 2 | May 26, 2006 07:27 |
