Calculating volume of Phase
Old   March 3, 2008, 12:50
Default Calculating volume of Phase
Pavan
Hi All, Assume that I have a problem with say 3 immiscible liquids with different densities such that liquid 1 is above liquid 2 which in turn is above liquid 3 in a cylindrical domain. The domain has a drain at the bottom from where the liquid (liq 3 to begin with) starts to flow out. After certain amount of flow time, if I were to calculate the mass/vol of say liquid 3 remaining in the domain, how would I calculate it?
I tried to use the report volume integral menu by calculating volume integral of field vairable -- Phases -- volume fraction -- liquid 3. This gives a volume in m3 which I then multiply with the density of liq 3 to get the mass. However, I am not sure this is the correct way to do it because I observed that when I use this procedure to calculate the volume of say liq 2 which is just floating down, the value of the volume changes over the flow time. This should not be the case because liq 2 hasn't been drained yet. It is a const density liq just moving down. I infer then that the vol integral is only providing a sum of volumes of each cell that holds that liq. I am a little confused about how I can calculate the volume that I want. Any ideas? Thanks.
Pavs
Old   March 3, 2008, 18:49
Default Re: Calculating volume of Phase
Aidan
setup a custom field function of Volume Fraction*Phase Density for each of your three phases. Then do a volume integral of the field function. This should give you the mass of each phase in the domain.
Old   March 5, 2008, 11:04
Pavan
Thanks Aidan. It was pretty much what I was doing. I was concerned about the difference I was seeing over flow time. But the error was less than 1.5% That still should not exist but I guess it could be numerical error or something. I guess I won't worry about it.
Mass fraction and volume fraction eric weddle CFX 0 September 26, 2011 06:02
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Liquid phase volume fraction sega OpenFOAM Running, Solving & CFD 23 August 21, 2008 06:58
Time-averaged phase volume fraction dlaw FLUENT 5 August 3, 2005 14:33
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
