Surface tension driven flow
Old   March 2, 2008, 05:24
Default Surface tension driven flow
Saeedeh Mohebbinia
Can anyone tell me how can I model a Surface tension driven flow?
Old   March 24, 2008, 00:51
Default Re: Surface tension driven flow
Alisher
Hi. Have you modeled a Surface tension driven flow. Because I also should model Surface tension driven flow for calculating Marangoni Number. But I do not know how to do it. Thanks.
Old   March 24, 2008, 02:07
Saeedeh
Hi, Yes, I have modeled it. you must Use VOF method which is used for simulating multiphase flows. If u use Fluent u can choose each phase and enter interfacial tension between them and activate the adhision to wall. And in your walls Boundary conditions u can enter the contact angle between the fluids and the wall.
Old   October 11, 2019, 13:12
Vijay S Duryodhan
vijud25 is on a distinguished road
Kindly let me know the inlet and outlet boundary conditions you have used for your case.
vijud25 is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
VOF and strong surface tension effect phsieh2005 Main CFD Forum 1 August 30, 2005 07:56
Free Surface Gravity Driven Flow Rupp Carriveau FLUENT 4 June 14, 2001 17:54
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 12:57
