help on import mesh file into Fluent
Old   February 29, 2008, 11:14
Default help on import mesh file into Fluent
hannah
Hi, I need your help on how to import mesh file produced using ICEM CFD 10 into Fluent. Is there any rule there?
It's really appreciated if anyone can help me here.
Thanks in advance
Hannah
Old   February 29, 2008, 11:48
Default Re: help on import mesh file into Fluent
myron
In ICEM: Output > Select Solver > Fluent V6. Then output to the solver - and ICEM writes a .msh file - then imported to Fluent.
Old   February 29, 2008, 12:42
hannah
Thank you, myron. But my ICEM CFD doesn't look like the solver for Fluent V6 there.
Regards
Old   March 1, 2008, 06:00
Vinod Dhiman
But it must have some Fluent solver, Fluent 4 or Fluent 5. That will do. And if it doesn't have any of them then ICEM might be missing some .dll or .so files as per your OS
Old   March 3, 2008, 15:32
hannah
Thank you Vinod. I got it.
Hannah
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
convert FLUENT mesh file to CFX mesh file?? frederic felten FLUENT 5 December 6, 1999 10:32
