help to build an atomization model Please
Old   February 22, 2008, 08:31
Default help to build an atomization model Please
Mido
Hi Im doing this for an important college project and as im not an expert in Fluent so im having some troubles, i have 3 meshes for a external mixing air-assist nozzle, one mesh for the liquid orifice, one mesh for the gas orifice and one mesh for the mixing zone. I want to use the outputs of the two first meshes as inputs in the mixing mesh and then simulate the atomization process. Can anyone guide me through this process and tell me if there are other BC needed in addition to the gas and the liquid inputs and the outflow faces. Any help is welcome . Thanks
Old   March 1, 2008, 09:39
Default Re: help to build an atomization model Please
Vinod Dhiman
Hi
You may not need any other inlets or outlets. Just provide BCs at two inlets and outlets. However, I hope you know that you have to merge these three meshes. You can do that either in Fluent or in TGrid.
Vinod Dhiman
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 20:13
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
