making both cores work
Old   February 21, 2008, 10:34
Default making both cores work
anup
i hv pentium D 2.8Ghz .how can i make both of my cores work simultaneouly .. apending -t2 in the shortcut did give me a feel that something is goin to happen ..but alas!! the CPU utilization showed only one core working at full capacity ... plz help me ..how to do it
Old   February 21, 2008, 22:21
Default Re: making both cores work
rodrigo
you have to disconnect the dual core function in your computer BIOS. At least it did function with an Hyper Threading Pentium processor.
Old   February 22, 2008, 07:39
Paolo Lampitella
I have a quad core q6600 and Windows vista. when i want to use the parallel version of Fluent i just go in the start menu, run... and digit:
C:\Fluent.Inc\ntbin\ntx86\fluent 3ddp -t2
where the last digit (2) means 2 processes. If i want to use 3 cores i digit:
C:\Fluent.Inc\ntbin\ntx86\fluent 3ddp -t3
and so on.
You can also go in the dos prompt and under the directory:
digit:
fluent 3ddp -t3
Old   February 22, 2008, 08:55
anup
i did that but that should mean that when i look through the task manager it should show both the cores working at 100% usage ..does it show in ur case?
Old   February 22, 2008, 09:27
anup
Host spawning Node 0 on machine "personal-b35842" (ntx86).
You can click CTRL+C to stop the startup process!
------------------------------------------------------------------------------ ID Comm. Hostname O.S. PID Mach ID HW ID Name ------------------------------------------------------------------------------ host net personal-b35842 Windows-32 4024 0 1508 Fluent Host n1 mpich2 personal-b35842 Windows-32 4080 0 1 Fluent Node n0* mpich2 personal-b35842 Windows-32 1888 0 0 Fluent Node
i got this message .. yippe i guess its working now ... but is there a software/test to check the cpu time req to perform a specific task
Old   February 22, 2008, 09:30
anup
i hv a doubt though even even no calcuations/iterations are done ..the cpu usage by fluent is 50% y is that so
Old   February 22, 2008, 13:02
Paolo Lampitella
I have not yet used it so much because i'm working on a 2D problem. But in the little test i've done i launched 3 processes and 3 cores were at about 95 - 100 %, the fourth core was at 50 %, maybe because it was the host.
However in my case Fluent displayed the same thing you posted
Old   February 22, 2008, 13:06
anup
thanks .. btw what do u do ? may i know more about u
Old   February 22, 2008, 13:19
Paolo Lampitella
You're welcome
I'm a graduate student in italy and i'm going to work on Synthetic Jets in straight channel with LES.
But, before to perform such a simulation, i'm testing the Fluent space and time discretization schemes with the Taylor solution in 2d.
Maybe, i'll have time to perform some straight channel LES simulations on the intel quadcore so i could go deep in multicore and say more about the performance of Fluent in this case.
Old   February 22, 2008, 13:21
anup
dude ..that was all latin to me ... i m a final year chemical engg undergraduate at the Indian institute of technology,kharagpur .. guess u hv heard about it ...
Old   February 22, 2008, 13:25
  #11
anup
last year i went to italy while i was in netherlands for my summer internship .. its much like india .. and a lot differnt than rest of the europe
Old   February 23, 2008, 05:27
  #12
Paolo Lampitella
Yes, italy is a lot different of the rest of Europe...in the worst sense possible. Actually italy it's going down so rapidly that everyone i know wants to go in other country to live. I'm also in a special situation, living in Campania which is now becomed a 4th world country because of the trash in every street and around every corner.
Well...let's leave this space to CFD stuff.
Bye
Old   February 26, 2008, 05:00
  #13
MS
Whom are you working under? Rof. S.Chakraborty or Prof. SK Dash?
Old   February 26, 2008, 05:04
  #14
anup
m working under prof G Das and Samantah ray .. btw who r u ?
Old   February 27, 2008, 03:53
  #15
MS
Sorry dude got ... got mixed up .. thought that u were from mechanical engineering...
I am a 2004 passout from Mech.
Old   February 27, 2008, 07:57
  #16
anup
well i m goin to pass in 2008.... m in iit kgp... whr r u now?
Old   February 28, 2008, 10:04
  #17
MS
I am a CFD analyst in an Automotive company.
Specify number of cores that CFX should use. Lance CFX 16 July 20, 2016 10:04
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Transient post-processing, Time averaged pressure work Turbomachine CFX 1 January 3, 2011 18:01
Selecting cores independently in a dual quad core machine jalarron FLUENT 1 September 7, 2009 18:06
Making errors stable Mihail Galabov Main CFD Forum 0 April 21, 2004 07:32
