Is UDF the only way to handle particle melting?
Old   February 20, 2008, 15:37
Default Is UDF the only way to handle particle melting?
marq
Dear friends,
I'm trying to simulate a single particle's melting process. But the solidificaltion/melting model in FLUENT(v6.3)is not fit in the pariticle melting case. Did some one know is there any other methods could be used to simulate particle melting process except UDF code? I appreciate your help very much.
Regards
Old   February 22, 2008, 01:55
Default Re: Is UDF the only way to handle particle melting
sudhir
what is the fluid r u using? can u explain ur process little more briefly?
Old   February 23, 2008, 01:02
marq
Thanks sudhir,
In my problem, a particle is injected into a furnace with hot air blowed in. The velocity of the particle is equal to the velocity of hot air. So, the particle is heated by the hot air to it's melting temperature and continue to melt until all of this particle is melted.
I want to know that can FLUENT simulate this particle melting process?
Old   February 23, 2008, 02:48
sudhir
hello marq.
multiphase flow is possible in soldification.for multiphase flow we can use VOF model....i dont know wehether we can give two velocity as u mention....plz confirm it with others... im sure that u can use only VOF flow for soldificaton model...
How to put melting point data of inert particle in DPM model of Fluent subhankar_bhandari Fluent UDF and Scheme Programming 1 February 5, 2018 08:08
Problem with a simple UDF to calculate cell-averaged particle values kmayank FLUENT 1 January 18, 2011 02:40
UDF for Particle reaction and DPM_Property saifulraju ANSYS 0 September 22, 2010 08:24
How to put melting point data of inert particle in DPM model of Fluent subhankar_bhandari FLUENT 0 July 28, 2010 08:40
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
