Modelling the movement of a liquid surface
Old   February 17, 2008, 08:52
Default Modelling the movement of a liquid surface
C. Lucero
Hello All,
I have to model a water tank with an inflow and an outflow in an unsteady 3D problem.
In the tank there is an interface water-air because the tank is not completely full. This surface is the one I want to model. I want to study its vertical movement.
Can anyone tell me which kind of grid or boundary condition I have to use?
Thanks in advance.
Old   February 17, 2008, 19:00
Default Re: Modelling the movement of a liquid surface
Manfred
I think you have to set up two different zones in Gambit, and the surface defined as Interface. Then in Fluent you can set up the material property for each zone. Anyway I am not sure this is the best way, try this and let me know
Old   February 18, 2008, 00:20
JSM
For interface tracking, vof model is best one. But depends upon the inlet and outlet of the geometry, Eulerian model or vof model can be used.
hope it will help you
JSM
Old   February 19, 2008, 18:42
C. Lucero
Thank you very much.
I will try and tell you.
Old   March 11, 2008, 14:56
samnetmoon
hi all some one xho can help me on modelling the movement of a liquid surface
Linear movement of corrugated surface in simpleSRFFoam bhh OpenFOAM 0 July 18, 2011 10:17
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
Modelling free surface waves with wave parameters utku FLUENT 0 December 6, 2004 09:30
Liquid film of water on an inclined surface Dr. Daniel Gubler Main CFD Forum 0 August 24, 2004 06:50
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
