Divergence problem for species transport model
Old   February 14, 2008, 01:33
Default Divergence problem for species transport model
MY
Hello all,
I'm solving a species transport model with wall surface reaction on parallel FLUENT. The surface reaction UDF is compiled fine and UDF library is loaded, but when calculation starts I get the following error:
divergence detected in AMG solver: species-0
Primitive Error at Node 0: floating point exception
Primitive Error at Node 1: floating point exception
Primitive Error at Node 3: floating point exception
Primitive Error at Node 4: floating point exception
Primitive Error at Node 2: floating point exception
Primitive Error at Node 5: floating point exception
Error: floating point exception
Error Object: #f
after about three iterations. The UDF defines a wall surface reaction rate for laminar finite-rate model and does not involve any calculation that requires sending or receiving data from another compute node (or the host) and therefore the code is not parallelised.
Can anyone guide me as to what might be the cause of this error?
Many thanks in advance
Old   April 7, 2012, 10:01
Default How to set boundary conditions
Soulstealer is on a distinguished road
I am a beginner in fluent and find it difficult to set up boundary conditions.
Can someone please help how to setup boundary conditions.I am given two options 1.interior-solid 2.wall-solid.
My project is to estimate the energy losses in an open channel bend.
Thank You for your response
Soulstealer is offline   Reply With Quote
Old   July 10, 2012, 10:18
Jeff
Bigunclejethro is on a distinguished road
Hi MY - from what I've read the floating point error occurs as a result of an impossible mathematical operation (ex - dividing by zero). I have yet to find out exactly how this happens but possible solutions include reducing your timestep (transient flow), reducing the courant number (coupled solver). These have worked for some people but have not worked for me. Maybe you will have better luck.
Soulstealer - you need to define the boundary names before going into fluent. This can be done in the Ansys Mesher by clicking on the face, right click and select named selection. Once this is done, FLUENT will show these boundaries in the Boundary Conditions panel and allow you to set them up
Bigunclejethro is offline   Reply With Quote
Old   January 11, 2014, 05:46
Default Species with boundary condition
Pramod Raj
tppraj is on a distinguished road
Hai friends,
I am new in fluent. I don't know how the species is introduced in the fluent for the nozzle flow. I am using the density based implicit solver with structured mesh. so please help me to introduce the species in the fluent.
Thanking you
tppraj is offline   Reply With Quote
Fixed Bed Gasifier, Species Transport Problem therandomestname FLUENT 12 January 4, 2019 08:08
Problem with turbulence model akonduri OpenFOAM 2 September 17, 2010 01:49
Is it possible to use divergence in the source term of an scalar transport equation? jannnesss CFX 0 January 8, 2010 20:53
lenght and number of nodes for an orifice meter flow problem - k-eps model fofo FLUENT 0 November 15, 2009 04:49
Converge problem of Mixture Model Jen FLUENT 8 August 17, 2005 19:23
