Supersonic flow past a wedge with counter flow
Old   February 14, 2008, 01:21
Default Supersonic flow past a wedge with counter flow
Mahesh Bailakanavar
I am modeling a supersonic flow past a wedge. The problem is 2-D symmetric (thus the model represents a ramp air intake). The inlet Mach number is 3.0 and the free stream stagnation pressure is 80 psia. There is a counter flow jet positioned one cm away from the wedge exit on the symmetry plane with a counter flow stagnation pressure of 80 psia and the flow is choked (M=1). I am using density based implicit solver with Spalart Allmaras turbulence model. On iterating the residual value does not drop below 10^-2. It keeps oscillating around this value, upto 10000 iterations. However, I have converged solutions for the same problem without the counterflow. Can any one suggest me ways to resolve this non-convergence issue. Thanks ahead of time for your advice. Regards Mahesh
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 16:13
mesh generation for supersonic flow followed by freestream padmanathan FLUENT 6 September 14, 2010 08:53
time step for inviscid supersonic wedge flow. yaseer Main CFD Forum 1 March 8, 2007 10:40
Laminar supersonic flow past bump in channel ganesh Main CFD Forum 0 December 20, 2006 16:48
Reg: Supersonic flow past backward facing step kiran Main CFD Forum 0 September 30, 2006 06:07
