EROSION UDF
Old   February 12, 2008, 01:03
Default EROSION UDF
shehab abdelrahman
hi every one : does any one here have a UDF for calculating the erosion rates under DPM method. I appreciate any ideas and I have the UDF manual but the only example there is for 2D-axis-symmetric only. So I need erosion UDF for 3-D utilization. thanks, shehab
Old   February 12, 2008, 06:15
Default Re: EROSION UDF
rana
there is already a built-in model in DPM (check the Fluent user's guide 6.3, Sept 2006) where you can find the details. however, if you can improvise according to your requirement, you need to write UDF indeed for the same. Check similar UDFs done in Fluent's UDF manual, Fluent 6.3, September 2006. It is not diffcult to incorporate the z-axis. the UDF example is also kept generalized, not for only axis-symmteric case only. this should be good starting point for your numerical work.
best of luck.
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
How to pass impact angle values in Erosion UDF sravan451 FLUENT 1 September 17, 2010 00:59
Erosion UDF in Eulerian approach sravan451 FLUENT 0 September 16, 2010 23:52
