Aero Acoustic - Postprocess-FWH Model- Octave Band
Old   February 8, 2008, 16:26
Default Aero Acoustic - Postprocess-FWH Model- Octave Band
Manoj Kumar
Hi Everyone
I am trying to carry out an aeroacoustic simulation using FWH model. During post processing when I plot the Sound Pressure Level(SPL) for the Octave band Frequencies using Fourier Transformation panel, only SPL corresponding to octave frequencies 16.5Hz to 500Hz is plotted. Generally it should be form 16.5 Hz to 16000Hz. Kindly help.
Thanks
Manoj
Old   October 11, 2012, 02:50
m13n
andi136 is on a distinguished road
Hi, Kumar.
How is your aeroaccoustic simulation? I like to simulate acoustic by using Fluent, but I don't know where to start.
Thank you.
Andi
andi136 is offline   Reply With Quote
Old   December 24, 2013, 22:00
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hi andi,
Any luck with your acoustics ? if you have finished do you know how to calculate 1/3 octave band of a particular set of frequency vs SPL values
Thanks,
Hasan K.J
Alhasan is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
DO radiation method, non-gray band model, UDF wouter Fluent UDF and Scheme Programming 5 March 23, 2017 23:03
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
software to model acoustic heating? knoken Main CFD Forum 0 June 24, 2010 17:33
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 05:37
