Fluent 6.3 on a Linux cluster
Old   February 8, 2008, 10:29
Default Fluent 6.3 on a Linux cluster
cfd_newbie
I'm working on a Linux cluster 32 bits, 5 nodes at 1.7 GHz and 2 GB of RAM on each node, the Fluent version is 6.3.
Well, I've done the same calculation on my Core Duo laptop 1.6 GHz and 2 GB of RAM, Linux on 32 bits - a simple 2D calculation, and ... the solution converged faster on my laptop.
This is something normal ? I mean a five nodes cluster should be much faster than my laptop.
Thanks in advance.
Old   February 8, 2008, 10:50
Default Re: Fluent 6.3 on a Linux cluster
Phil
What is the cell count? Very low cell counts dont scale well over a cluster. You need >100k cells per cpu core.
Old   February 8, 2008, 10:54
mAx
not necessary you should use your cluster with 3d calculations or with a minimum of cells. try the same with a 3d model, you should see the difference
Old   February 8, 2008, 11:01
cfd_newbie
I use for this problem a very dense mesh 300000 cells, your suggestion is to use only 3 processors for the job ?
Old   February 8, 2008, 12:09
Phil
I dont bother with parallel under 300k cells PER CORE i.e. minimum 600k cells per dual core machine.
fluent 12.1, batch mode in linux sakalido FLUENT 13 September 27, 2017 09:55
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 03:44
Fluent 12.1 on Linux x64 Architecture Issue fivos FLUENT 5 April 24, 2010 16:19
FLUENT in Linux L3munoz Hardware 4 October 29, 2009 05:58
Fluent on Linux Cluster george FLUENT 0 August 11, 2006 05:57
