particle tracks in black
Old   February 6, 2008, 06:56
Default particle tracks in black
rana
hi,
in DPM model, i want to view the particle tracks (released from injection) in black by default, it gives colored particle tracks, colored by particle residence time.
can anyone help ?
thanking you.
Old   February 6, 2008, 09:24
Default Re: particle tracks in black
Kalous
Hi, You could use a gray colormap in View > Colormaps and then specify range <0,0> in Particle Track panel. But I think you wanted something a bit more sophisticated...
Kalous
Old   February 6, 2008, 10:30
rana
hi,
i didn't understand where to give <0,0> in Particle track panel..can u tell me the appropriate toolbar
however, even with above, the tracks are coming in various shades of gray..but i want all track lines in single color i.e., black.
hope to get a reply
best regards.
Old   February 6, 2008, 13:04
kalous
Hi, I suppose you use GUI and plot your particle tracks in Display > Particle tracks. Deselect the "Auto range" option and enter 0 as both limits of the range manualy. (I tried this with Color particle tracks by: Particle Variables > Residence Time, but it should work with Particle ID too.)
I am not at a computer with Fluent installed right now, so my answer might be a bit inaccurate.
Kalous
Old   February 7, 2008, 05:27
rana
sir, if we put 0 manually in the opton, no particle track is visible. this is also obvious isnt it ? because we are actually making the residence time as 0 (both in min and max) i tried this with both particle ID, residence time, it is the same for all the cases. after making gray in colormap, i am getting all in B&W, but in various shades of gray. i tried to improvise further and reduced the no. of scales to 3, but still i have 2 shades..and this is what nagging me..
hope to get a feedback.
best regards.
Old   February 7, 2008, 06:41
Kalous
I don't know. Works fine when I try it. Another option is to create your own colormap that is all black. You can do so in Display > Colormaps > Edit. However this is just improvising. For example if you want to plot contours of velocity on the background and afterwards black particle tracks, this doesn't work, because the colormap of velocity contours changes to black as well.
Best regards.
Old   February 7, 2008, 09:23
rana
yes, it does with HSV activated under edit
i reduced the colormap size = 2, for getting atleast 50 % of it as black..but what about the rest ???
Exporting multiple flow data from particle tracks andreas_haakansson FLUENT 6 March 16, 2011 02:34
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Particle Tracks Anand Siemens 2 October 10, 2005 14:38
Particle Tracks not visible Henrik Ström FLUENT 6 September 14, 2005 09:04
Particle tracks Sridhar FLUENT 0 October 5, 2002 13:19
