Gambit HEX core method gives unwanted 2D region |
February 3, 2008, 06:21 |
Hi there,
I meshed one conical volume with Hexa-core method and it gave me a very GOOD quality HEX dominated mesh with few layers of pyramids and prisms around hexa. But When I save the mesh in ANSYS format to import in CFX-11, I see that mesh contains a 2D primitive region right where pyramids start around the region of HEX elements. But I did not define or create this region in Gambit. I do not want to have this 2D region created at all because this gives me problem in CFX-11(It would fall under wall category). 1) I do not understand how come this 2D region exists. Any idea? Is it a problem with HEX-core scheme? 2)Is there any way out to get rid of this region? 3) Will saving the mesh in some other format work? Thanks a lot in advance for your help ! Best Regards, KK |
February 4, 2008, 10:31 |
Re: Gambit HEX core method gives unwanted 2D regio
i dont know CFX much,but principally you can manipulat mesh in CFX like in fluent(merging, split,...),(in CFX pre),right?maybe you should post you question in CFX Forum
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
[ICEM] how can i create a consistent transitions between tet and hex? specifically my model? | snailstb | ANSYS Meshing & Geometry | 3 | March 15, 2010 21:26 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
