February 1, 2008, 10:28 |
Different Flow in One Case
Hello everyone, got a problem...
Here is the case: I have a tube in tube case which includes 2 kinds of flow. The inner flow is Turbulent but the outer flow is Laminar. The two flow are sperated by a steel tube which is solid. The temperature of the two flow are different,so there is heat flux go through the steel tube leading to thermal exchang of the two flows. Questions: (1)Can I specify different model for the 2 kinds of flow in one case? (2)Can I specify different solver setting for the 2 kinds of flow in one case? Thanks very much. |
Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case | LittleBart | Main CFD Forum | 5 | January 10, 2011 16:07 |
3D Incompressible turbulent flow validation case | Yu | Main CFD Forum | 2 | April 4, 2008 04:13 |
how to predict unsteady flow from case definition? | Felix | Main CFD Forum | 6 | August 28, 2007 17:40 |
Validation case for turbulent flow | Ratan | Main CFD Forum | 0 | October 4, 2005 04:02 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 06:18 |
