SPACE SHUTTLE REENTRY & CFD SIMULATION
Old   January 31, 2008, 15:20
Default SPACE SHUTTLE REENTRY & CFD SIMULATION
Sheikh Tamjid Mashrafi
I AM A STUDENT OF BUET(BANGLADESH UNIVERSITY OF ENGINEERING & TECHNOLOGY), OF MECHANICAL DEPT.
I AM WORKING ON THE SPACE SHUTTLE REENTRY PHENOMENON USING CFD , FOR MY UNDER-GRADUATE COURSE. I WILL USE A 3-D MODEL OF SPACE SHUTTLE COLUMBIA & STUDY THE FOLLOWING-
1)HIGH VELOCITY FLUID FLOW
2)TEMPERATURE DISTRIBUTION & HEAT TRANSFER
3)EFFECT OF BROKEN TILE DURING REENTRY
I NEED SOME DOCUMENTATION , PREVIOS WORK , DATA ON THIS TOPICS.SO THAT I CAN MY WORK.
I AM REQUESTING ALL CONCERNED PEOPLE TO SEND ME ANY LINK, OR ANY SOURCE FROM WHICH I CAN GET IT.
ITS URGENT.
EMAIL ADDRESS : tamjid208@yahoo.com
Old   February 1, 2008, 16:29
Default Re: SPACE SHUTTLE REENTRY & CFD SIMULATION
jiju
I do not have any info about your project but i would like to give you an advice. I think you are trying to bite off more than you would ever be able to chew for an undergraduate project. You want to run 3D simulation of space shuttle re-entery phenomenon which is extremely complicated issue. You should first consider following points before you can take up on this project.
1. Do you have computer resource to run this problem. You will have to generate million of cells for your grid. Are you gone run it on parallel.
2. How would you validate your results
3. What type of computer modelling you are considering to do. Traditional RANS modelling is bound to give poor predicitions in your case.
4. How would you set up your boundary conditions and what would be the size of your domain.
Once you have looked into these issues you may re-consider your choice for an undergraduate project. I hope i am not too discouraging.
Regards Jiju
Old   February 4, 2008, 15:39
RE13
I think you are over ambitious, this type of project would take a year for a team of highly experienced CFD experts, and you propose to do this as an undergraduate project? Nothings impossible I say, but the issue of computer resources as noted by the above poster would be your main limitation assuming you have the knowledge required to carry this project out to the end.
CFD simulation with sliding meshes ivanddd FLUENT 0 April 16, 2011 18:26
Is it a difficult & challengin CFD simulation case Sarwa FLUENT 2 November 29, 2006 13:56
Car/Truck traffic Simulation with CFD ?? Thierry FLUENT 2 April 10, 2003 19:48
Solidification CFD simulation Min-Hua Wang FLUENT 0 February 28, 2001 18:40
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 18:25
