weld pool simulation using Fluent
Old   January 31, 2008, 14:09
Default weld pool simulation using Fluent
rahul
Can any body help me in "Weld pool simulation using Fluent"
Can get paid for it.
Old   February 5, 2008, 05:06
Default Re: weld pool simulation using Fluent
sana
please, tell me what is your problem exactly, and i hope that i can help you.
Old   February 5, 2008, 19:57
Usman
How much are you paying? Are you gone charge him for your service sana. It sounds like man is loaded!
Usman
Old   February 6, 2008, 13:03
rahul
well its the weld pool simulation of Gas Tungsten Arc Welding process i have a weld bead 2D heating it with gaussian heat flux
there are some marangoni boundary conditions applied to it
if can tell me your email ID i can send you the report i just need help how to proceed ....for every help i am ready to pay... i need guidance
Old   February 9, 2008, 12:07
Usman
Hi Rahul
If you scroll up, right next to "Posted By: Usman" there is an e-mail addresse. Send your problem and questions, i will have a look through them and advice you accordingly. I can help you for free buddy (if i can at all). Thats what these forums are for.
Usman
Old   February 11, 2008, 02:13
rahul
Hello Usman
Thanks a loot But friend i want to send an attachment of the simulation ....thats why i want to know your email id
Regards Rahul
Old   February 11, 2008, 07:15
Usman
Hi Rahul
Just send me an e-mail, i will get back to you. Then you can send me an attachment.
Usman
Old   February 14, 2008, 02:01
Abir
Hi Rahul,
Could you tell me if you were able to solve your problem. I need to do the same in 3D. I am unable to write the UDFs. I have the governing equations and boundary conditons.
Can you or anyone else help me with the UDFs.
Thanks
Old   February 14, 2008, 06:03
rahul
ok sure!
Old   February 14, 2008, 06:27
Abir
Hi Rahul, As u might be aware there are 3 governing equations that need to be solved viz. Momentum conservation equation, continuity equation and the modified energy equation. Apart from these there are the boundary conditions which need to be incorporated. Could you send me across the UDFs which you have used in your work for 2D and I shall try and figure out the 3D versions of it.
If you need to have a look at the equations send me an email at abir01@iitb.ac.in and I can attach you a file with all the equations.
Old   December 2, 2013, 03:04
rohit
thomasrohit is on a distinguished road
hii rahul pls send all material regarding your work in welding 2d simulation to rohit131@gmail.com i m doing my project in that
thomasrohit is offline   Reply With Quote
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
Fluent simulation over airships Aragon FLUENT 0 March 27, 2009 13:38
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
HELP!:CFD modelling using FLUENT in swimming pool Tee Main CFD Forum 0 September 7, 2005 21:48
Convert existing Star-CD simulation to FLUENT Lam FLUENT 3 June 10, 2003 13:00
