Airfoil at stall angle
Old   January 28, 2008, 12:24
Default Airfoil at stall angle
cfd_newbie
I'm interested in simulating the flow around an airfoil at a high angle of attack for identifying the stall angle:
Naca 2415
alfa=10-18 deg
Mach=0.2
Re=3000000
The above test case is taken from Abbott, the stall angle for NACA 2415 is at 14 degree.
In Fluent 2ddp I use the Spalart-Allmaras turbulence model but I found the stall angle for this case at 17 degree.
Could anyone explain me why I found such a deviation from experimental data. In my opinion the causes could be:
1. 3D effects.
2. The turbulence model.
Thanks in advance.
Old   January 28, 2008, 12:48
Default Re: Airfoil at stall angle
Phil
Massive separation is often poorly predicted by RANS. You may need to use DES.
Old   January 28, 2008, 18:19
Chris
Try SST turbulence model with very fine grid. How did you take into account turbulence in your model. You need to give more information about your model. You should be able to predict stall angle with RANS modelling (personal opinion).
Chris
Old   January 29, 2008, 10:39
cfd_newbie
I used a fine mesh, with y+<=1 and approximately 300000 quad cells, but a 2D domain. For turbulence I used the Spalart Allmaras model.
I never used SST turbulence model.
Old   January 29, 2008, 10:41
cfd_newbie
Thanks Phil, but I'm not ready to use a 3D mesh right now ( I need more hardware resources).
Old   January 29, 2008, 11:32
Chris
You used three hundred thousands cells for 2D problem! Can i have a look at your mesh. If you use this fine mesh for RANS modelling it would give you shit results. With mesh fine as this you will be resolving your reynols stresses directly where as RANS turbulence model would still be using eddy viscosity. That is my guess, but i can only confirm it after looking at your mesh. Do you mind if i can have a look at it.
Chris
Old   January 29, 2008, 17:35
cfd_newbie
I don't mind. How may I send you a picture of the mesh ?
Old   January 30, 2008, 07:23
Chris
cfd.student@gmail.com
Old   January 30, 2008, 11:30
Chris
I looked at your mesh it looks very fine as i was expecting. If you have obtained good results with this mesh at different angles of attack then mesh should not be a problem as you mentioned in your e-mail. It has to be turbulence model then! Some RANS models are not good at predicting separation in the flow, try another turbulence model.
Regards Chris
Old   January 30, 2008, 14:36
cfd_newbie
Thanks, Chris.
Old   February 5, 2008, 12:33
  #11
hassan kassem
S-A is good but to use it you must know the transition point first by a experimental data and that is difficult because you will need to change the default values in the S-A and that need more experience. so try SST transition or RSM with enhanced wall treatment with a very fine grid y+=1 and check for it during the solution especially at first
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Determining Stall Angle of 2D Airfoil Active.Aero.Fiero FLUENT 3 October 27, 2010 10:07
airfoil stall marek CFX 1 November 21, 2007 17:16
Modelling flow over airfoil at near stall angle Kelvin FLUENT 5 June 6, 2007 03:00
Divergence problem when airfoil exceed pitch angle zonexo Main CFD Forum 2 April 4, 2007 05:22
