jet breakup basics
Old   January 27, 2008, 11:47
Default jet breakup basics
alex
Hi. I need some help on the following topics:
1) Having laminar jet:
1.1. will running transient vof make jets' surface unsteady? will there be any ripples/waves?
1.2. will running steady vof converge to some solution? will this solution have ripples/waves?
1.3. may I trust to one of the above?
1.4. if turbulent unsteady/steady vof is applied to a laminar jet will it supress the "instabilities"?
2) Having turbulent jet:
2.1. what turbulent model is preffered to be used in plain round jet into air breakup?
2.2. should the model be transient implicit...?
3) Is there some published evidence on validating the breakup of round liquid jet?
Thank you very much.
Old   January 29, 2008, 04:09
Default Re: jet breakup basics
bohis
I know my friend has similar problem. The jet break-up occured only when there was a fixed difference between the veocity of jet and ambient.
good luck
By the way, you can use laminar flow. Apparently, it seems to be easier to produce waves
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 05:54
2D Plane Jet Fluent Solution doug Main CFD Forum 11 February 4, 2019 10:34
determination of jet front Fred CFX 5 February 11, 2007 13:01
Jet Breakup in FLUENT obby FLUENT 3 May 26, 2005 10:09
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 23:11
