help! heat transfer through wall
Old   January 27, 2008, 00:59
Default help! heat transfer through wall
harry
Hi guys,
I am currently doing simulation of combustion occur in a microchannel (3D). My problem is after the combustion occur, i should expect a non-uniform temperature distribution along the wall due to the heat transfer from the combustion mixture through the wall. however, my result only show a uniform temperature which dont really make sense. Moreover, both the inner and outer wall shares the same temperature. i have set my boundary condition of wall to coupled. anybody can help ? the error is cause by boundary conditon or meshing? anybody have idea? thanks a lot.
regards harry
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 16:35
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 09:48
how to model heat transfer for the coupled wall jing113cn FLUENT 0 June 22, 2009 04:56
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
