Sudden non covergence of k-e
Old   January 24, 2008, 15:32
Default Sudden non covergence of k-e
Anastasios
Dear friends,
I am running a 3d simulation using k-e turbulence model among others. My simulation is unsteady and converges very well maximum 25 iterations until time step 203. After that all the equations including continuity converge except the epsilon (e)equation from the k-e model.
My flow is a two-phase flow. One primary phase and one secondary granular phase.
Can anyone comment on the sudden non convergence of e?
Thanks very much in advance,
Anastasios
Old   January 26, 2008, 08:07
Default Re: Sudden non covergence of k-e
none
what type of flow regime you working with? is it stratified annular, bubbly....etc? what the under-relaxation factor for turbulent dissipation rate (e) you have been used? did you simulate with the VOF model?
Old   January 27, 2008, 08:06
Anastasios Georgoulas
No i am simulating a 2 -phase flow using the eulerian mixture model. One phase is sea water (primary)and the other one is fine sand (secondary). I am using the default under relaxation factor.
I used the adaptive time step ption and i noticed that fluent automatically reduces the time step and the solution now is converging more quickly!
Meshing Sudden Contraction and Expansion carldaru ANSYS Meshing & Geometry 33 January 27, 2017 01:56
sudden drop in solver monitor jiguozhao CFX 3 February 27, 2011 06:34
Simulation of suspension flow at sudden contractio QM Main CFD Forum 1 August 5, 2010 16:13
Pressure loss due to sudden expansion in pipe flow Ahmed FLUENT 0 January 2, 2006 11:01
sudden perturbations adarsh Main CFD Forum 0 June 11, 2002 13:08
