Problem making a periodic boundary in helical coil
Old   January 24, 2008, 11:22
Default Problem making a periodic boundary in helical coil
Mikael
I'm trying to estimate the heat transfer (Nu number) in a helical coil at fully developed flow. As I dont have a tube that is sufficiently long to get fully developed flow I need to make the boundaries periodic instead. I have coupled the surfaces in Gambit (added them both to one surface that is periodic) and exported the geometry to FLUENT. Under the periodic conditions menu I have chosen -specify mass flow = 2.45 -pressure gradient = 0 flow direction z=1 (the flow enters in the z-direction and leaves in z-direction) Relaxation = 0.5 Number of iterations = 2
When Im doing the simulations I get a mass flow of approx 10e-7 kg/s...Very far from 2.45 kg/s
Somebody knows what could be wrong? And is it even possible to use periodic boundaries for such a geometry?
Greatful for an answear!
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 03:18
Problem with using periodic boundary conditions Sun FLUENT 0 January 14, 2011 10:47
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 29, 2010 00:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
problem in meshing a periodic boundary dumas FLUENT 4 March 8, 2006 11:54
