contour of 3d velocity magnitude as data file
Old   January 24, 2008, 01:13
Default contour of 3d velocity magnitude as data file
frantov
hi How can I save the results of a 3d velocity field as a data file (x,y,z) in order to plot it in other application? I would like to obtain a similar plot like the -contour plot- obtained in Fluent postprocessor, but using a different software. thanks.... fran
Old   January 24, 2008, 01:19
Default Re: contour of 3d velocity magnitude as data file
frantov
hi... searching in the forum I found the answer.... thks anyway
File-> export
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
How to indicate velocity magnitude in tecplot with Flow-3d file? his124 FLOW-3D 1 June 27, 2011 11:54
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
