compiled UDF....HOW?
Old   January 23, 2008, 00:15
Default compiled UDF....HOW?
shehab abdelrahman
hi all the forum: HOW to get the fluent opened from the visual studio prompt command ?..to use a compiled UDF i must open fluent from the command prompt of visual studio... how can I do that...any one have steps or something?
Old   January 23, 2008, 03:12
Default Re: compiled UDF....HOW?
Mira
Hello Shehab,
normally this should also work with the Fluent GUI. You need Visual Studio installed on your computer. Then open Fluent and your cas (and dat) -file and go to Define -> User-Defined -> Functions -> Compiled and Add your udf-file there. First Build and then Load it.
I read something about the visual studio prompt command at the udf-Manual, but I didn't get it, too. But this way works also ...
Best regards, Mira
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
I want to use pressure of 1 face in udf that compiled on other face iman_1844 Fluent UDF and Scheme Programming 3 June 10, 2010 13:55
Why udf can not be compiled in my pc? Xinqiang FLUENT 0 June 10, 2009 15:32
difference between udf compiled and udf interprete chandra sekhar FLUENT 2 April 11, 2006 01:04
how to quit compiled or interprited UDF tian FLUENT 0 April 9, 2003 00:53
