cavitation bubble collapse
Old   January 21, 2008, 17:50
Default cavitation bubble collapse
iceman
Hi Does somebody try to simulate the collapse of a water vapor bubble? I initialize Fluent 6.3 with a radius bubble of 5 mm Pv=2360Pa and a fluid (water) pressure of 100000Pa (1bar).The mesh is a quarter of a circle, on one segment I impose the boundary condition axis and for the other segment I impose a symmetry condition and I use the 2D axisymetric solver. I use a time step of 1e-07s, k-eps realizable, mixture model. With these parameters I could see the collapse in about 6e-04s (experiment: 4,5e-04)but the pressure due to the collapse at 3mm and 10mm of the bubble center are very low compare to the experiment (I find 3 and 1,5 bar compare than 250 and 80). I try to use a smaller step time, Quick scheme but it s not better. So if somebody has the solution or an idea it would be nice.
Thanks
Old   January 22, 2008, 15:51
Default Re: cavitation bubble collapse
iceman
Nobody for my problem??
Old   January 24, 2008, 06:04
mateus
It's interesting what you do...I tried to do something similarly some time ago. But no success. I think the problem is much more complicated as it looks. I think you at least need to treat both fluids compressible. Why do you use k-e model? If you have so tiny (and dense) mesh it's hard to talk about turbulence...I think you can use laminar flow...
I know I didn't help you much but maybe we could try to do something together...
Mateus
Old   January 24, 2008, 08:18
iceman
I'm going to simulate using laminar flow. I tried to simulate using the option ideal gaz for the vapor but it didn't work, there was water liquid inside the water vapor (it's not very physic) What was the size of your bubble ? me 4,15mm the time step? me 1e-07 and 20 iterations per time step but I need to initialize with 1e-07 and 150 iterations per time step during 100 iterations. Did you see the collapse ?
Somebody tells me that Knudsen number is not very low for this simulation, so the Navier-Stokes equations may not be used for this problem, what do you think about that?
I'll be there in 6 hours bye
Iceman
Old   January 31, 2008, 18:58
ROOZBEH
Hi friends;
I have simulated formation of the near wall collapsing bubble induced jet using Fluent and submit a journal paper about a subject related to this phenomenon. Be sure that if the bubble size is in order of 1mm, the flow field is laminar. I applied VOF approach. Using mixture approach will be failed because there is a sharp interface between the vapor inside the bubble and the outside water. I assumed compressible gas inside the bubble and incompressible liquid outside the bubble. One important matter is that when you assume the incompressible liquid, you should set an outlet as a part of the outer boundary of your solution domain.
regards, ROOZBEH
Old   February 5, 2008, 17:28
iceman
What do you put for fraction gaz non condensable ?? Why do you use compressible gaz? Could you send me your paper about the collapse bubble??I m very interested by this.
Thanks
Iceman
Old   June 18, 2012, 14:17
navid
ndabir is on a distinguished road
Hi
have you solved your problem? I am doing the same simulation but I can't see the collapse of bubble. Does it have any trick for simulation? could you please let me know what was your problem and how did you solve it? I am using first order upwind for my simulation. Do you think I should use second order?
Thank you
ndabir is offline   Reply With Quote
bubbel collapse in cavitation Aniss FLUENT 2 July 6, 2012 13:44
cavitation bubble collapse Aniss FLUENT 2 July 18, 2006 09:59
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 01:02
Hot gas bubble collapse in cool water William Palm FLUENT 1 April 20, 2005 11:53
How Bubble Radius is Found in Cavitation Chris Siemens 7 June 22, 2004 13:43
