Open Channel Boundary Conditions via journal
Old   January 21, 2008, 12:05
Default Open Channel Boundary Conditions via journal
Matteo
Hi, I have a problem in imposing boundary conditions for open channel model via journal file (and in TUI mode too).
1) I define the VOF - Open Channel model
/define/models/multiphase/vof 2 explicit 0.25 no yes yes
2) I define my inlet as pressure inlet:
/define/boundary-conditions/modify-zone/zone-type inlet pressure-inlet
3) I try to define the open channel boundary conditions:
/define/boundary-conditions/pressure-inlet
(inlet)
zone id/name [inlet] inlet
(mixture water air)
domain id/name [mixture] mixture
Open Channel [no] yes
Use Profile for Gauge Total Pressure? [no] no
Gauge Total Pressure (pascal) [0] 0
Use Profile for Supersonic/Initial Gauge Pressure? [no] no
Supersonic/Initial Gauge Pressure (pascal) [0] 0
Direction Specification Method: Direction Vector [no] no
Direction Specification Method: Normal to Boundary [yes] yes
Turbulent Specification Method: K and Epsilon [yes] no
Turbulent Specification Method: Intensity and Length Scale [no] no
Turbulent Specification Method: Intensity and Viscosity Ratio [no] yes
Turbulent Intensity (%) [10] 2
Turbulent Viscosity Ratio [10] 10
why after the setting "Open Channel [no] yes" fluent asks me input for the Gauge pressure?
4)If I try the command a second time fluent ask me the correct thing:
: /define/boundary-conditions/pressure-inlet
(inlet)
(mixture water air)
Open Channel [yes] yes
Inlet Group ID [1] 1
Secondary Phase for Inlet: water [yes] yes
Flow Specification Method: Free Surface Level and Velocity [yes] yes
Free Surface Level (m) [0] 0
Bottom Level (m) [0] -4
Use Profile for Velocity Magnitude? [no] no
Velocity Magnitude (m/s) [0] 5
Turbulent Specification Method: K and Epsilon [no] no
Turbulent Specification Method: Intensity and Viscosity Ratio [yes] yes
Turbulent Intensity (%) [2] 2
5) When I start the simulation I have a SEGMENTATION VIOLATION error, probably for the double imposition of B.C.
/usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26[0xdbd48b] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26[0xdbd3e1] /lib64/tls/libpthread.so.0[0x36ccc0c430] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(Compute_Node_Weights+0xd2)[0x6c62b4] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(Node_Scalar_Boundary_Reconstruct+0x7 d)[0x6c5d45] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(Set_Channel_Froud_Number_twophase+0x 1f9)[0xa20edb] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(Update_Open_Channel_Parameters+0x8d)[0xa20291] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(Update_Physical_Time+0x5d3)[0x5706af] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26[0x5c1f31] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(eval+0x773)[0xe02043] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(eval+0x860)[0xe02130] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(eval+0x460)[0xe01d30] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(eval+0x49a)[0xe01d6a] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26[0xe0337c] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(eval_errprotect+0x32)[0xe02d12] /usr/local/Fluent.Inc/fluent6.3.26/lnamd64/3ddp/fluent.6.3.26(eval+0x860)[0xe02130]
Error: fluent.6.3.26 received a fatal signal (SEGMENTATION VIOLATION). Error Object: #f Done. ()
Can anyone help me? I'm trying to write a journal file for my simulation but i can't solve this error. Thanks in advance Matteo
boundary conditions in FLUENT VOF for open channel flow newcomer Fluent Multiphase 33 May 28, 2024 14:41
Open Channel Flow - Setting Boundary Conditions Christine Sindelar FLUENT 6 June 6, 2011 05:11
Problem with Boundary Conditions using a journal file T.S. FLUENT 3 July 27, 2009 09:31
open channel flow boundary conditions yan FLUENT 0 July 5, 2005 00:36
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
