Zero Diffusive flux
Old   January 19, 2008, 14:01
Default Zero Diffusive flux
Subramani Sockalingam
I am running an external compressible flow steady state laminar model.I have modeled air as a reacting gas consisting of N2,O2,N,O and NO in FLUENT. I was able to run the simulation until Mach 12 after that it diverges with the error that mass diffusivity is zero. I have modeled mass diffusivity of the mixture using kinetic theory and I have defined the L-J parameters for all the species. I also tried to model using multi component diffusion by modeling the diffusion coefficients as polynomials for the interacting pairs. I got the same error after Mach 12. warning: Mass_Diffusivity: invalid (zero) diffusivity Please check material properties. Please give your thoughts on what could be wrong.
Thanks, Subramani
Old   May 27, 2009, 11:36
Default Mass_Diffusivity: invalid (zero) diffusivity.
ibrahim
Ibrahim4435 is on a distinguished road
I am simulating a reactive flow. The reactions only take place on surface of catalyst. I considered species transport and when I assign source tems I get error from Fluent "Warning: Mass_Diffusivity: invalid (zero) diffusivity.
I used Lennard Jones model and kinetic theory for mass diffusion. When I do not use source terms, I do not get this error. As far as I know my diffusivity has nothing to do with source term and I guess the error message is not exactly describing the error.
Anyboy can help me please?
Ibrahim4435 is offline   Reply With Quote
Diffusive flux in interMixingFoam oswald OpenFOAM Programming & Development 28 August 15, 2018 00:05
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 10:50
Zero Diffusive flux Subramani Sockalingam Main CFD Forum 0 January 19, 2008 14:02
Help: diffusive flux BC at wall Quarkz Main CFD Forum 7 July 17, 2005 12:24
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
