January 17, 2008, 05:01 |
scheme and udf
hello dear, (bc (zone-name wall mixture) ( (react? . #t) )) is there anybody knows how to use "id-name" in stead of "zone-name"? Thanks
January 17, 2008, 10:10 |
Re: scheme and udf
for more details, I'd like to know the name of the boundary condition from its ID using an UDF in order to have the ability to use the following function: (bc (zone-name wall mixture) ( (react? . #t) )). I am hardly blocked, I hope that you have the write solution
January 17, 2008, 11:11 |
Re: scheme and udf
http://fluid.jku.at/personen/javurek/pdf/scheme.pdf take a look at page11
January 18, 2008, 04:36 |
Re: scheme and udf
Hi mAx. Thank you
January 18, 2008, 10:33 |
Re: scheme and udf
Hello mAx, it is always me. I have to write about 50 Zone-names using the following command: rps = RP_Get_String("zone-names"); When I use the program: .jou ans .c (UDF)(http://fluid.jku.at/personen/javurek/pdf/scheme.pdf take a look at page11 ), it gives me only the first 10 Zone-names. So, I lose the 40 athors. Is there any limitation about the array length "RP_Get_String"? else, do you have a better solution?
January 18, 2008, 10:45 |
Re: scheme and udf
no sorry i am not so familiar with scheme I just knew that there was an udf for scheme-programing on the web.
changing scheme variable with UDF? | Wagemakers | FLUENT | 17 | September 30, 2015 15:34 |
How to combine UDF and Scheme? | ali hemmati | Fluent UDF and Scheme Programming | 3 | March 19, 2011 15:45 |
How to implement a numerical scheme by using UDF? | Furui Xiong | FLUENT | 0 | July 29, 2010 02:30 |
Boundary Condition Types Using Scheme and UDF | Nasir | FLUENT | 0 | September 15, 2008 22:54 |
Scheme and Fluent UDF? | Arthur Valais | FLUENT | 11 | January 31, 2000 14:19 |
