dynamic mesh and udf problem
Old   January 17, 2008, 02:57
Default dynamic mesh and udf problem
boboroo
I want to simulate a tank with 60% water in it. The tank sways in a changeable omega value which changes with time. The swirl axis is y.
I use the vof modle, and write an udf as follows, set the omega relation and compile it into my fluent case. Then I set the wall of the tank with this udf in "define â€" dynamic mesh- zone".
Ps: in " define-boundary conditions ", because there is the udf to define its motion so I set the walls of the tank stationary as default.
But after I iterate for some steps, the water in the tank sways but the tank itself doesn't. Who could tell me what the problem in my work? Why the wall were stationary but the water sloshed? And whether my udf below is right? Thanks very much.
# include "udf.h"
DEFINE_CG_MOTION(swaytank, dt, vel, omega, time, dtime)
{ Thread *tf = DT_THREAD (dt);
face_t f;
real NV_VEC (axis);
int n;
/* set the swirl axis*/
NV_D (axis, =, 0.0, 1.0, 0.0);
begin_f_loop (f,tf)
/*set the omega relation*/
omega[1] = 0.21 * 0.26 * cos (0.21 * time);
end_f_loop (f, tf); }
Old   January 20, 2008, 22:26
Default Re: dynamic mesh and udf problem
boboroo
anybody could give me some suggestion?
problem with udf for dynamic mesh ja92 FLUENT 0 February 24, 2011 10:32
Dynamic mesh UDF problem Peter FLUENT 2 November 12, 2007 03:10
a problem about DEFINE_GEOM in dynamic mesh UDF speedcat FLUENT 1 May 16, 2005 04:09
Problem related with UDF for dynamic mesh Ryan FLUENT 6 April 29, 2004 10:29
UDF & Dynamic Mesh Tutorail Problem Qureshi FLUENT 6 February 6, 2004 04:52
