Moving wall with sin function
Old   January 16, 2008, 11:09
Default Moving wall with sin function
Malik
I summarize my problem. I would like to move the upper wall along Y axis with a sin function type by using UDf. V1 is the wall velocity in the x direction. scheme below
___________________________ V1=10m/s (upper wall)
___________________________ V2=0m/s (lower wall)
^Y | |___>X
thank you!!!!
Old   January 17, 2008, 08:14
Default Re: Moving wall with sin function
Malik
/************************************************** ********** * * wall motion * ************************************************** **********/
#include "udf.h"
DEFINE_GC_MOTION(rotor,dt,vel,time,dtime) {
/* a est l'amplitude,Y la periode,u rotor velocity along x*/
double a; double W; double t; double dt; double u;
a=0.2; Y=10; u=100; t=CURRENT_TIME; dt=CURRENT_TIMESTEP;
/* set velocity along Y v = a*sin(2Pi*dt/T) */
vel[1] = a*sin((2*3,14159265*t/W)+dt); vel[0]= u;
Can you tell me if it's good....?
My best regards,...malik.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Wall function formulation in CFX and Fluent gravis ANSYS 0 May 4, 2010 12:03
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
