UDM derivatives for - for EHD flow
Old   January 15, 2008, 10:42
Default UDM derivatives for - for EHD flow
Sandilya Garimella
Hello All
I am writing a UDF to solve for two scalars with source terms
The details of user defined scalars are UDS0 is potential UDS1 is charge density I am solving for an EHD flow
now using a formula I am writing a UDM such that UDM0 = f(UDS0) UDM1 = f(UDS1) where f() represents "function of"
Now the source terms of my equations for UDS0 and UDS1 depend upon derivatives of UDM0 and UDM1 hence I need to calculate these derivatives
Now, Derivatives for UDS in any cell can be got by UDSI_G(c,t,f)[]
Similarly is there a macro to get derivatives of UDM in each cell
Would be glad if someone could point me to correct source or solution to my requirement
Thank you
Regards Sandilya
Old   January 15, 2008, 10:44
Default Re: UDM derivatives for - for EHD flow
Sandilya Garimella
Hello All
I am writing a UDF to solve for two scalars with source terms.
Now using a formula I am writing a UDM such that UDM0 = f(UDS0) UDM1 = f(UDS1) where f() represents "function of"
Now the source terms of my equations for UDS0 and UDS1 depend upon derivatives of UDM0 and UDM1 hence I need to calculate these derivatives.
Thank you
Regards Sandilya
Old   January 15, 2008, 13:06
RE13
Have you tried manually calculating the derivatives in the the source code?
Old   January 15, 2008, 13:09
Sandilya Garimella
I did and it works but the expressions are cumbersome and i want to make code easily understandable!!! Can we extract derivatives of UDM's?
Old   January 16, 2008, 03:23
Reza
Hi,Sandilya. As I know for modeling of EHD with fluent you need to calculate E that is derivative of potential. For this you must define Ex and Ey in the Adjust part of your UDF like this:"C_UDMI(c,t,0)=C_UDSI(c,t,0);C_UDMI(c,t,1)=C_ UDSI_G(c,t,0)[0];C_UDMI(c,t,2)=C_UDSI_G(c,t,0)[1];" where C_UDSI(c,t,0) is potential. After this, you can use C_UDMI(c,t,1),C_UDMI(c,t,2) in other parts of your UDF for Ex and Ey. I hope this is useful for you.
Regards
Old   July 9, 2009, 08:49
Akour
ak6g08 is on a distinguished road
Sandiya,
This is very late...but I am trying to do a ehd simulation as well and am having problems with one of the source terms in the space charge transport equation, whenever I have a source term as dV/dX (gradient of potential), my solution diverges...I have tried storing the gradients in a define adjust and then using the C_UDMI values...but it doesnt make a difference...so when I add the source term Q*E_x on the x-direction momentum equation as:
C_UDSI(c,t,1)*C_UDSI_G(c,t,0)[0]
the solution diverges...and the same goes for the source term in the space charge transport equation which depends on electric field...please help if you can
AK
akour
ak6g08 is offline   Reply With Quote
Old   August 24, 2011, 12:50
sarah
nangless is on a distinguished road
Send a message via MSN to nangless
Hi Reza - regarding your code above, why do you need the line C_UDMI(c,t,0) = C_UDSI(c,t,0) if you are not using it in calculating the components of electric fields. I am trying to do this also and I'm getting access errors even when I include this line. The following is my adjust function - if you spot any major errors please let me know.
#include "udf.h"
#include "sg.h"
DEFINE_ADJUST(udf_adjust, domain)
Thread *t;
cell_t c;
thread_loop_c(t,domain)
begin_c_loop(c,t)
C_UDMI(c,t,0) = C_UDSI(c,t,0) ;
/* udm 0 -> Electric field axial component */
C_UDMI(c,t,1) = - C_UDSI_G(c,t,0)[0] ;
/* udm 1 -> Electric field radial component */
C_UDMI(c,t,2) = - C_UDSI_G(c,t,0)[1] ;
/* udm 2 -> Electric field magnitude */
C_UDMI(c,t,3) = NV_MAG(C_UDSI_G(c,t,0)) ;
end_c_loop(c,t)
nangless is offline   Reply With Quote
Old   September 9, 2013, 04:17
Smile
ehsan
ehsan.utsc is on a distinguished road
Hi,can any body help me about ehd on fluent,i have some experimental data on ehd.i want to model it in fluent but i have not any code of ehd in fluent.please help me abut how to model ehd in fluent,thank you.
e.shabahang@gmail.com
ehsan.utsc is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 10:49
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
