granular multiphase models
Old   January 14, 2008, 19:09
Default granular multiphase models
lurk
Does anyone know where to find some good documentation on the equations solved by fluent 6.3 for granular phase multiphase models. regards lurk
Old   January 15, 2008, 05:55
Default Re: granular multiphase models
manish rane @ IIT BOMBAY
Hi Lurk
Sorry I don't have proper solution to your problem. May I come to know about your working area i.e. problem definition??
I am currently working on Modelling of Circulating Fluidised Bed Boiler using FLUENT(Basically gas-solid two phase flow). In this I have to impose partial slip boundary condition for solids. Can you help in this if possible?
Thanx
MANISH RANE IIT BOMBAY MUMBAI,INDIA
Old   January 15, 2008, 07:36
lurk
are you using the mixdure model? i simulate a bubbeling fluidized bed. there i use the Eulerian model. and the model are ok, but when you are defining the particle properties there is no good documentation on the equations solved fore the different properties.
Old   January 23, 2008, 00:05
shehab abdelrahman
hi Lurk: i want to use fluent to simulate the two-phase slurry flow (liquid-solid)using the kinetic theory. i have some good documentation but don't know how to set up the viscosity of the granular flow. the fluent need to input Lennard-Jones parameters ( segma) and (epsilon/boltzmann constant). i don't have these parameters for the sand particles, can you help me in this issue. I think you ,I and Manish are working in the same field and will be very helpful for all of us to share our knowledge and information. my e-mail is: shebos@hotmail.com
Old   January 23, 2008, 05:51
lurk
I don't know, but these days i am taking my main theases in fluidized bed, and i an investigating the equations. I will tell you if i find out something -lurk
how to use MIXSIM to simulate multiphase models weiz FLUENT 1 November 26, 2009 01:40
How to give volume fraction in multiphase models chhanwal FLUENT 0 August 13, 2009 01:07
Multiphase Euler Granular Parameter Javier FLUENT 1 June 1, 2007 07:29
Multiphase models Nima Sheyad FLUENT 7 November 4, 2002 09:20
granular multiphase model daninwin FLUENT 1 June 18, 2001 12:36
