natural convection/vertical flat plate
Old   January 14, 2008, 13:25
Default natural convection/vertical flat plate
N. Norris
I'm trying to model 2D laminar free convection on a vertical flat plate.
- My domain is 1m(height)x 10m(width)
- Isothermal wall on the left boundary where the heating starts 1/3 of the way up the wall
- Symmetry on the right boundary, pressure outlet and inlet on the top and bottom respectively
- incompressible ideal gas model for variable density
- body force weighted solver
My problem is in my results. The buoyant flow is there, however there is a small, but noticeable downflow throughout the domain. When I compare the pressures across the inlet and outlet, there is a significant difference which seems to be driving this downward flow, even though I had set them both to be constant at 0 Pa.
Is there something I am missing in setting up the pressure boundary conditions?
Old   January 15, 2008, 05:44
Default Re: natural convection/vertical flat plate
al_c
Try switching on Operating density (Define->Operating Conditions), and set Operating density by value of density of ambient flow.
Old   January 17, 2008, 14:59
N. Norris
Thanks for your response
I tried as you said to change the operating density to the ambient value but it seems to have had no effect in terms of reducing the downward flow
Old   August 18, 2013, 10:08
Shaon
Navid450 is on a distinguished road
Have you solved your problem?
Navid450 is offline   Reply With Quote
Flow Over a Flat Plate recon9 CFX 1 January 20, 2011 22:09
Calculate Drag force for flat plate vsun FLUENT 0 October 3, 2010 08:56
entrance of a flat plate mc Main CFD Forum 0 April 24, 2007 23:38
Conjugate heat transfer for film-cooled flat plate Michele FLUENT 0 July 3, 2006 09:42
Seperated Flow and Turbulence modelling flat plate Simon Mizzi Main CFD Forum 1 December 16, 2003 02:26
