how does it affect????????
Old   January 14, 2008, 00:22
Default how does it affect????????
jamal
i am solving a laminar flow across a cylinder.i am interested in getting a good vortex shedding in unsteady flow. i want to know how this time step size,no. of time steps and no. of iterations per time step affect this phenomenon....
thanks a lot friends
Old   January 14, 2008, 05:57
Default Re: how does it affect????????
kris
you should consider physical time scale
if incompressible flow, you should consider a turbulent time scale which is probably smallest time scale.
if compressible flow, you should consider a speed of sound for non-reacting flow due to smallest time scale
if reacting flow, you should consider chemical time scale, maybe 10^-6 or more
you should need no. 100 samples for 1-period.
good luck
Old   January 14, 2008, 08:30
Sham
To get a good vortex shedding you need to make sure that your mesh is fine enough and also your time step is small enough. To do this, you need to do some mesh dependence studies and also time step convergence study. I always keep the CFL number less than 1 to make sure your time step is small enough. If you keep your time step size small enough, you need not to worry about no. of time steps and no. of iterations per time step.
Sham.
Old   January 16, 2008, 00:05
jamal
thanks a lot friends..
Does buoyancy affect mass diffusion? evcelica Main CFD Forum 2 August 9, 2011 11:25
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 12:58
How much surfactant affect surface tension qunwuhe@hotmail.com Main CFD Forum 0 June 7, 2007 06:01
How surface tension affect delta t? Pei-Yng Hsieh Main CFD Forum 3 February 25, 2005 11:55
Fluid flow will affect with different diffusivity? tseo FLUENT 0 January 17, 2005 02:41
