Can someone help me on setting boundary, continuum
Old   January 12, 2008, 04:28
Default Can someone help me on setting boundary, continuum
Michaelkoay
Hello, can someone shed some lights on how to set the boundary conditions and continuum type? Can you pls explain each types of the boundary types i.e. wall, axis etc.? And also shed some lights on the continuum types i.e. how to use it?
I need it to simulate gas flow in a imaginary gas chamber to investigate its flow characteristic. In the chamber, should I set it wall or symmety on the surfaces on which the gas flow?
Just the above problem for now, pls help me and thank you very much!!
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Warning 097- AB Siemens 6 November 15, 2004 05:41
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
