execute command error
Old   January 9, 2008, 06:37
Default execute command error
Virag Mishra
Hi ALL
I am trying to extract the values of field variables at every timestep for a unsteady case the command used by me in the solve>execute commands is
file/export/ascii/File_data-%t u1u1 u2u2 udm-19 udm-20 () u1u1, u2u2 are defined by costum field function and udm is user defined memory
but I am getting an error as following "GENERAL-CAR-CDR:INVALID ARGUMENT [1]:IMPROPER LIST ERROR OBJECT #f"
More over what changes should I make in the command to write the values of variables only on a a particular surface id.
Old   January 10, 2008, 17:59
Default Re: execute command error
Meng
u can write a journal file first and then use "execute commands" to execute this journal
Execute a Fortran program with Fluent marye FLUENT 6 December 9, 2019 19:53
Cannot execute cpp in UDF bowling FLUENT 2 January 5, 2018 12:05
execute udf in ss & transient simulation hosseinhgf FLUENT 0 December 1, 2010 09:41
error while execute on demand Anderson Main CFD Forum 4 October 17, 2008 12:48
Execute Commands from input file Greg Z FLUENT 1 May 24, 2006 17:56
