about turbulent viscosity limited
Old   January 3, 2008, 23:40
Default about turbulent viscosity limited
Jason
Dear All, during the Fluent iteration, I got the message of" turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 211 cells". Who can give me some advice of that? Thanks! Jason
Old   January 5, 2008, 05:13
Default Re: about turbulent viscosity limited
DEV
Dear Jason,
Give few details about your case.
Generally lower down your urfs, solve flow first and then turbulence, change turbulence model from std to RNG...
Old   January 6, 2008, 22:11
Ertan Karaismail CFD&AMP
Check your mesh quality
Old   January 6, 2008, 22:41
Jason
Dear DEV,
thanks for you kindly help. I found most of the cells that over the turbulent viscosity limited are local in the inlet. my simulation is just about the flow in some simple air path. I use the mass flow inlet. Isn't the mass flow inlet boundary will cause this problem?
Old   January 8, 2008, 08:09
Jinsong Yang
check your mesh quality, make sure the Y+ value matches to the tuburlent model and near-wall treatment. you can refer to this website: http://geolab.larc.nasa.gov/APPS/YPlus/
Old   January 9, 2008, 02:16
Amit
Other way is go to control-limits, change the value(increase) of turbulent viscosity.
Old   January 25, 2008, 07:21
nagi
hi,
there may 3 main reasons for that.
1.bad quality mesh.
2.improper boundary condition for turbulence
3.improper turbulence model..
check your qty,relax urf,if u solve for second order solve for first order then switch to second order.... use simple turbulence models for inital iteration then go for higher models...many times reducing the value of TI% for some iteration will work.
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 07:15
turbulent viscosity limited to viscosity ratio of? mechfloeng FLUENT 4 February 6, 2014 13:45
Turbulent viscosity limited to viscosity... Cyril FLUENT 16 October 4, 2007 07:12
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 21:34
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
