PCM solidification
Old   January 2, 2008, 04:37
Default PCM solidification
sudhir
hello frnds,
im doing a project on solidification of phase change materials(PCM) .generally pcm have different densities on different temperature.is it possible to solve this kind problem using fluent??
thanks
Old   January 2, 2008, 10:05
Default Re: PCM solidification
qayum
you can give properties using piece wise lenier option there u can give properties according temperature. for this u need properties of fluid with respective temperatures.
qayum
PCM melting inside the Al cavity shoxan FLUENT 1 August 9, 2018 03:12
How can I make the solid PCM to sink to the bottom as it melts? Lim FLUENT 6 December 22, 2014 03:29
About the solidification? H.P.LIU Phoenics 1 December 1, 2010 10:49
use k-epsilon model for solidification 4mr1 CFX 0 July 6, 2010 06:49
PCM solidification sudhir FLUENT 0 January 2, 2008 04:36
