December 28, 2007, 19:55 |
Gambit on Opensuse install error
I tried to install Gambit.v2.3.16 (linux) on OpenSuse 10.3 (x86_64) and this error message appeared:
-------------------- thiago@linux-dowc:~> FLUENT_ARCH=lnx86 gambit LANG pt_BR.UTF-8 changed temporarily to en_US for gambit use. Starting /opt/gambit/Fluent.Inc/gambit2.3.16/lnx86/gambit ... Gambit build SP2006033020. libxcb: WARNING! Program tries to unlock a connection without having acquired a lock first, which indicates a programming error. There will be no further warnings about this issue. libxcb: WARNING! Program tries to lock an already locked connection, which indicates a programming error. There will be no further warnings about this issue. gambit: xcb_lock.c:77: _XGetXCBBuffer: Assertion `((int) ((xcb_req) - (dpy->request)) >= 0)' failed. Received exception: SIGABRT (abort signal) Please send the GAMBIT.6616/jou and GAMBIT.6616/trn files to your local Fluent office or distributor. Also send a message including any relevant errors or warnings you see above in this window. You may wish to delete the temporary directory GAMBIT.6616 after sending the above files. ERROR: Please retain a copy of the GAMBIT.6616/jou, GAMBIT.6616/trn, and GAMBIT.6616/*.dbs files, any imported geometry and any relevant errors or warnings you see above in this window and contact support at your local Fluent office or distributor. Abortado thiago@linux-dowc:~> -------------------- I did not install Fluent yet. This may cause any problem? Thankz for any help. |
December 29, 2007, 12:22 |
Re: Gambit on Opensuse install error
Now I tried to run the program using "FLUENT_ARCH=lnx86 gambit -x11" and it worked, but the fonts doesn't appear on the menu and the buttons. i have just squares instead of letters.
what can i do now? thkz. |
December 30, 2007, 00:06 |
I guess you try to install a 32 bits version of Gambit on a 64 bits operating system. Contact your Fluent provider for the proper Gambit version.
December 30, 2007, 19:26 |
Thanks cfd-newbie. I think that the problem was because I hadn't installed Fluent yet. After installing Fluent the fonts appeared on Gambit and the program worked alright.
p.s.: sorry for my bad english. |
December 23, 2010, 23:23 |
need gambit for linux
Vigneshram
Rep Power: 16 |
any one pls give me a link for gambit for linux os............. Thanks
January 2, 2011, 14:26 |
senthilkumar.R
Rep Power: 16 |
Hai vicky,
I'm Searching for the same in Last 20 days but could not get. If anyone know reply with details to get Gambit and Fluent installation package for linux.
Senthil Kumar. R Department of space Engineering and Rocketry, Birla Institute of Technology,Mesra. rock.senthilkumar@gmail.com |
September 4, 2011, 06:25 |
#7 | |
Mohammad
Rep Power: 16 |
I had searched a lot to find gambit for Linux but I found only old version(2.2) which cannot open files created with 2.3.16 version of gambit. as the ansys co. removed gambit from its products totally, it seems that we don't have any choice of buying or downloading gambit for Linux. if I remember correctly, the 64 bit version of gambit had created only for Linux and it is an interesting choice for cases with high number of cells. if anyone found a gambit for Linux link, please send it to us. yours, Mohammad |
December 14, 2013, 08:59 |
thanks
Rep Power: 13 |
Thiago,thanks very much for your "FLUENT_ARCH=lnx86 gambit -x11". It worked like charming!
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 21:23 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
